[Da...] Posted 17 hours ago Share Posted 17 hours ago Hello everyone, is it possible to scale a model with pcm command. we have some simple parts that expand in one direction, they can have different lengths but our base cad model is only 1mm. so right now we scale our models and save them as individual cad models in our inspection directory. the idea would be to have only one model and scale it via a pcm command. thanks in advance Link to comment Share on other sites More sharing options...
[Ch...] Posted 10 hours ago Share Posted 10 hours ago Calypso is not really a CAD editor more of a CAD reader only. I love the idea of scaling, and it may be possible with the engine - but currently there is no way I know if. NX and most CAD software do have a scale tool. PCM however is made for measuring different scale parts or part families. So if you don't really need the CAD model, PCM might be the way to go to simplify the programs using VARiables. Good luck. Link to comment Share on other sites More sharing options...
[Ma...] Posted 10 hours ago Share Posted 10 hours ago Please sign in to view this username. But Calypso is capable of scale model. Manually with window, but is. 1 Link to comment Share on other sites More sharing options...
[Ch...] Posted 10 hours ago Share Posted 10 hours ago Please sign in to view this username. Wow, I did send come commands via PCM to the acis engine, however is a bit tricky. Interesting to know - I think I'll give it a go sometime later. Thanks for the info. Chris Link to comment Share on other sites More sharing options...
[Ch...] Posted 9 hours ago Share Posted 9 hours ago Please sign in to view this username. Wow, I did send come commands via PCM to the acis engine, however is a bit tricky. Can you share code, does entity:scale work or is it old entity:transform ? Interesting to know - I think I'll give it a go sometime later. Thanks for the info. Link to comment Share on other sites More sharing options...
[Ma...] Posted 8 hours ago Share Posted 8 hours ago Please sign in to view this username. I wasn't talking about pcm, but manually by transform, there is scaling - so there can be a undocumented pcm for that perhaps. Link to comment Share on other sites More sharing options...
[Ch...] Posted 8 hours ago Share Posted 8 hours ago can you share the ACIS code? if so I can make it into PCM ... 😃 Link to comment Share on other sites More sharing options...
[Ma...] Posted 8 hours ago Share Posted 8 hours ago Please sign in to view this username. Are we on same page? Open Calypso -> menu CAD -> something with entities, where you can rotate and transform model. There should be on bottom scaling a model with number. If you need increase by 5% then you use 1.05. Not right now at Calypso and i am not sure how to obtain and send what you are asking for. 1 Link to comment Share on other sites More sharing options...
[Ch...] Posted 8 hours ago Share Posted 8 hours ago Ah yes, here you go, wow its been a long time since Ive used this .. Link to comment Share on other sites More sharing options...
[Ch...] Posted 8 hours ago Share Posted 8 hours ago This is theoretically possible with PMC but much easier here to scale and save the files needed, then you can clear and Load them with PCM. Link to comment Share on other sites More sharing options...
[Ma...] Posted 7 hours ago Share Posted 7 hours ago Fun fact: you can select curve spline in hierarchy and mirror it with button - perhaps can scale too. You can not select spline here so you have to select it at hierarchy before swithing to this tab. 1 Link to comment Share on other sites More sharing options...
