[Lu...] Posted May 22, 2025 Share Posted May 22, 2025 I have a surface with a surface profile call out on the surface but the profile is only called out on a portion of the surface. I use the patch tool and deselect through surface to remove the surface not included in the profile. When I go to construct>surface>Patch compound from CAD it selects the whole surface regardless of the area I select. Link to comment Share on other sites More sharing options...
[Na...] Posted May 23, 2025 Share Posted May 23, 2025 Hi Luciano, the SW can only create surfaces from the complete patch. Ideally the patch for this check would be constructed with the limited portion. You can however apply your selection to the actual surface element (select it -> F4 or RMB -> edit creation parameters -> deselect -> OK). Nanno Link to comment Share on other sites More sharing options...
