Loop within a loop - or how to measure the same loop, multiple times?
Hi.
Attached I have made a beautiful schematic drawing. It shows what I am working with; basically I have one plate with 9x11 products in it. But the products are divided by 3x11 products, then a bit of extra space and then again.
I have been able to make a loop to measure 3x11 products. But how do I then make a jump to the other products so that I can measure 9x11 products in one run?
Hope you can help.
Kind regards.
Make all initial features which can be looped without space, then make loop to fill whole block. If loop criteria are not changed, then you can reuse loop on other blocks.
I don't remember, but maybe you can select some iterations to be skipped.
  • Thank you! 1
Ran into some different issues, but the Dutch dept of Zeiss is looking at my inspection program as we speak. So hopefully. But other wise I found a way, as I said; measure 1 product, create a loop for 3x11, and do that 3 times to get to 9x11. Works, but not as conveniently as I would have liked. Now if I want to add or change a measurement, I have to do it trice. But a well. Better than having to measure 9x11 by hand 😉
Thanks for your help.
Great point, Chris! I completely forget about this pattern way too often; its versatility, even on nearly-regular patterns, is super useful. This approach scales a lot better if there are many features in need of patterning, and it’s far more intuitive than trying to understand a dense formula.
  • Like! 3
Great point
I also tend to forget about the pre-programmed list, but it's a powerful function with many use cases.
Patterns and loops are a way of thinking that can be strengthened over time and with use, similar to degrees of freedom and orthographic projection... or reading sheet music or flying a downed alien spacecraft from a bunker in Area-52.  All neuroplasticity and synaptic pruning and reinforcement.
