Loop within a loop - or how to measure the same loop, multiple times?
Hi.
Attached I have made a beautiful schematic drawing. It shows what I am working with; basically I have one plate with 9x11 products in it. But the products are divided by 3x11 products, then a bit of extra space and then again.
I have been able to make a loop to measure 3x11 products. But how do I then make a jump to the other products so that I can measure 9x11 products in one run?
Hope you can help.
Kind regards.
I think you can not use this. We already tried looping of a pattern and it's a no-go.
That's quite shocking, to be honest. So what would be the alternative? Measure 3 products, and have those individually loop 3x11?
Make all initial features which can be looped without space, then make loop to fill whole block. If loop criteria are not changed, then you can reuse loop on other blocks.
I don't remember, but maybe you can select some iterations to be skipped.
  • Thank you! 1
Yeah I think this is what I have now. Any tips on speeding up the measurement? Thanks for your replies by the way.
 I hope you found a way - i'm out of Calypso for a week. With loop you can speed up programming, not measurements.
Ran into some different issues, but the Dutch dept of Zeiss is looking at my inspection program as we speak. So hopefully. But other wise I found a way, as I said; measure 1 product, create a loop for 3x11, and do that 3 times to get to 9x11. Works, but not as conveniently as I would have liked. Now if I want to add or change a measurement, I have to do it trice. But a well. Better than having to measure 9x11 by hand 😉
Thanks for your help.
  I'm uber impressed with your solution and explanation.  It will be interesting to hear if this solves
's issue.  Thanks for the contribution.
wow
, thank you so much for this. Let my try to get to work with this today and see if I can get to resolve the issue. I'll report back, but thanks a lot for taking the time to reply!
Great point, Chris! I completely forget about this pattern way too often; its versatility, even on nearly-regular patterns, is super useful. This approach scales a lot better if there are many features in need of patterning, and it’s far more intuitive than trying to understand a dense formula.
  • Like! 2
I have yet to find the time to look at this. I've tried working with the code, but weird things are happening. Tomorrow, perhaps, an expert of sorts is coming by, perhaps I can have a look at it with him. I'll keep you posted!
We've settled for this. I've manually entered all product coordinates. It's somewhat time consuming, but at least it works and is easy enough to document.
Thanks everyone, great help!
