[To...] Posted May 27, 2025 Share Posted May 27, 2025 Hello quality heroes.... DuraMax was working on Friday, but today, the machine tab is missing. Checked the config folder and the DuraMax folder is there. This happened before and then fixed itself. I understand that I can create a new machine tab, but I would really like to understand what cause this to happen. Link to comment Share on other sites More sharing options...
[Ma...] Posted May 27, 2025 Share Posted May 27, 2025 Hey Tom - would you consider having an app, which would run in background, keeping history of config files, so you could bring back older version of certain file? All i would need to know is what files should be kept ( some can potentionally change with usage of Calypso ) and i would make that app. Anyone willing to contribute ideas for that app just PM me - or continue in this thread 🙂 Link to comment Share on other sites More sharing options...
[To...] Posted May 27, 2025 Author Share Posted May 27, 2025 That's a cool idea. Thanks for the offer. Will that fix the current situation? Link to comment Share on other sites More sharing options...
[Ma...] Posted May 27, 2025 Share Posted May 27, 2025 Current - sadly no 🙁 Link to comment Share on other sites More sharing options...
[To...] Posted May 27, 2025 Author Share Posted May 27, 2025 Since this is the second time this has happened, I think I should look into your solution. What info do you need from me? Link to comment Share on other sites More sharing options...
[Ma...] Posted May 27, 2025 Share Posted May 27, 2025 Mostly what files are critical - or i can implement file / folder selection with interval. You can suggest some files/paths because i won't see Calypso for at least two weeks. I can not find how to implement git features, so i'll be doing history within zip archive. Link to comment Share on other sites More sharing options...
[Ky...] Posted May 27, 2025 Share Posted May 27, 2025 Hey Tom, Did you have a power outage, or perhaps did someone turn off the computer with Calypso still running? That's when I usually see this. Otherwise, perhaps some sort of security thing.... When you type the name of the machine tab back in in the CMM settings, it does recognize that the folder is there, correct? As a side note, I know you know how to do this, but just in case someone comes by looking for help for this later, here is a document on how to resolve this issue: https://portal.zeiss.com/knowledge-base?id=483015 1 1 Link to comment Share on other sites More sharing options...
[To...] Posted May 28, 2025 Author Share Posted May 28, 2025 Please sign in to view this username. Thank you, Kyle. I did not know there was a documented procedure for this issue. I will give this a look as soon as possible. Link to comment Share on other sites More sharing options...
[Ma...] Posted June 3, 2025 Share Posted June 3, 2025 Please sign in to view this username. Soon i'll start to test my app. If you wish to collaborate about visuals, settings and behaviour of that app, PM me. Next app will be viewer of Calypso program. Any ideas will be helpful. 1 Link to comment Share on other sites More sharing options...
[To...] Posted June 3, 2025 Author Share Posted June 3, 2025 Please sign in to view this quote. Please sign in to view this username. Kyle posted an KB article on how to fix this issue. It worked perfectly. Thanks. 1 Link to comment Share on other sites More sharing options...
[Ma...] Posted June 3, 2025 Share Posted June 3, 2025 OK, so i'll finish it, place it on my github and start working on Calypso program viewer 🙂 1 Link to comment Share on other sites More sharing options...
[Ma...] Posted June 4, 2025 Share Posted June 4, 2025 Hi, to me there are 2 known events which could cause CALYPSO to lose the "connection" to the folder. 1. Which Kyle already mentioned is a power outage. 2. If the C:\ drive is full. Like literally no more space to write data. Best Regards Marcel 1 Link to comment Share on other sites More sharing options...
