Feature on PDF not Recalcualting
GOM Professional 2017
I was unsure where to post this. I have a program with a Python script that
Polygonizes
Recalcs the whole program Alignments, features, and inspection criteria
Exports a CSV PDF G3D
Saves ATOS
Closes out the software to allow a new instance to appear.
My issue,
I have an Element group that is used to find a range. When the PDF is exported, that Element Group used for RANGE is  ???. BUT it reports on the CSV. Now if i go into the ATOS Project, F4 (Edit) the feature, it will now populate into the PDF. Ive tried adding a recalc to the individual feature, ive tried to recalc the whole PDF report page, ive tried a manual stop of the script to edit the feature. Im out of ideas on how to get this one feature to populate within the script.
Thanks
       Dustin
Hi,
have you added also the checks of each element also to the element group to ensure that these checks are calculated before the element group itself is evaluated?
We added some improvements and bugfixes in the last eight years, may be updating to an actual version could solve your problem?
If this not fixes your problem you have to contact your local ZEISS partner!
Regards
