PCM command for sending pdf report to different directory
I created a report_end bat file below that sends a new pdf report to a network drive for others to look at around the facilty. I put it in the main Inspection folder. No issues other than with IT occasionally.
@echo off
xcopy "C:\Users\Public\Documents\Zeiss\CALYPSO\workarea\results" "Z:\Powertrain\Lab Operations\QUALITY\Reports" /D /E /Y /C
exit
Question: Is there a PCM option to do similar. Grab the pdf report and send it elsewhere to a different directory? I've seen copyFile mentioned and a report_end_pcm.txt file mentioned. I guess I'm looking for the command to actually "send" it.
Thanks in advance.
copyFile("C:\Users\Public\Documents\Zeiss\CALYPSO\workarea\results\NameOfYourReport.pdf", "Z:\Powertrain\Lab Operations\QUALITY\Reports\NameOfYourReport.pdf")
copy your report and paste it in the new folder
Thanks. I just have to add a time stamp or similar somehow so it always copies the last one ran
I tried this and it does work for the exact file name, but not the next run. I could probably delete the old file (from C:\) but would like to leave it. I have to figure out some sort of wildcard that or time stamp that differentiates the files coming from C:\
in my inspection_start_pcm.txt I create a date-/time-variable named DatumFile that I use for naming my report-PDFs. I create it like that:
Datum = dateInNumbers()
Zeit = time()
Tag = strElement(1,".",Datum)
if len(Tag) == 1 then
    Tag = text("0",Tag)
endif
Monat = strElement(2,".", Datum)
if len(Monat) == 1 then
    Monat = text("0",Monat)
endif
Jahr = strElement(3,".", Datum)
Stunde = strElement(1,":",Zeit)
Minute = strElement(2,":",Zeit)
Sekunde = strElement(3,":",Zeit)
ZeitF = Stunde+"_"+Minute+"_"+Sekunde
DatumFile = Jahr+Monat+Tag+"__"+ZeitF
Where I create the path and the name of my PDFs, I do it like: mypath+"\"+DatumFile+".pdf"
when you do it similar, and then use that variable in your copyFile()-command, it will allways take the actual report:
vReportName=DatumFile+".pdf"
copyFile("C:\Users\Public\Documents\Zeiss\CALYPSO\workarea\results\vReportName", "Z:\Powertrain\Lab Operations\QUALITY\Reports\vReportName")
  • Like! 1
  • 4 weeks later...
//Set your destination path
CalypsoEndRslt = "C:\Users\Public\Documents\Zeiss\CALYPSO\workarea\results"
CalypsoReslt   = directoryPath("results")+"\"
DateTime = " - "+dateInNumbers()+" - "+time()
PDF_gra   = CalypsoReslt+getRecordHead("planid")+"_"+getRecordHead("partnbinc")+"_gra.pdf"
PDF_ptx   = CalypsoReslt+getRecordHead("planid")+"_"+getRecordHead("partnbinc")+"_ptx.pdf"
PDF_all   = CalypsoReslt+getRecordHead("planid")+"_"+getRecordHead("partnbinc")+"_all.pdf"
PathforPDF=CalypsoEndRslt+getRecordHead("planid")+" - "+getRecordHead("measRun")+" - "+DateTime
waitForFile(PDF_gra,"waiting for PDF",0,15,"no PDF found",0)
if fileExists(PDF_all)
    deleteFile(PDF_gra)
    deleteFile(PDF_ptx)
    copyFile(PDF_all,PathforPDF+".pdf")
        deleteFile(PDF_all)
else
    copyFile(PDF_gra,PathforPDF+".pdf")
        deleteFile(PDF_gra)
endif
  • Like! 4
