Combination of 3D and 2D measurements in one project
Hello,
we would like to combine the measurements performed with an ARAMIS 4M in 3D-Setup and a 2D Camera (Baumer, 12 MP, USB 3).
We can aquire the pictures either using Snap or Matlab and importing the pictures afterwards.
Would it possible to combine both measurements in one project?
The motivation is to determine the bending portion in a compression test.
Please let me know if you need more information.
Best Regards,
Luciano Avila Gray
Yes, it is possible.
First create two projects with the same number of synced stages and orient both. Especially the 2D project should be scaled right.
Save both projects.
Open one of the projects - the one with AD values and triggered time stamps.
Drag&Drop the other project file into the opened project in GOM Software and select "Add measurement series".
Now you have two measurement series in one project and can create elements from them and evaluate.
