pywin32 library installation
The win32api library requires you to install the pywin32 library.
I'm not able to use it inside GOM 2021, but I am able to use it on my Windows installation using the pycharm IDE.
The reason I can use it on my Windows python installation is because there is a post script you are supposed to run that registers the dll's needed:
python -m pywin32_postinstall -install
So I tried to run that post install script from here and it looked liked it worked, but I am still unable to use the pywin32 library/module inside GOM. I get an error that the win32api module cannot be found.
"C:\Users\user\AppData\Roaming\GOM\2021\python\bin\pywin32_postinstall.py"
Any help would be appreciated, thanks.
  • 2 weeks later...
you can try that:
Copy the three DLL files in the \Lib\site-packages\pywin32_system32 directory to the Windows\system32 directory
