[na...] Posted June 6, 2025 Share Posted June 6, 2025 (edited) I wanted to test self-centering probing with slightly different nominal values on each run, so GPT-4 wrote this code for me: // Generate a pseudo-random number using system time and CMM position LongStringOfNumbers = millisecondClockValue().asString.hash + getPositionCMM().x.asString.hash + getPositionCMM().y.asString.hash + getPositionCMM().z.asString.hash // Convert the long string to a number RandomHighValue = val(LongStringOfNumbers) // Get a random number between 1 and 100 RandomValueBetween = mod(RandomHighValue, 100) + 1 I let it run overnight and it worked perfectly, but I'm not sure if I just got lucky or if it might cause unexpected behavior with CMM in the future. So I all ears for your opinions. Edited June 6, 2025 Link to comment Share on other sites More sharing options...
[Ma...] Posted June 6, 2025 Share Posted June 6, 2025 Am i missing something? What it should do? Machine do self-centering if it's capable of by measuring force direction. Link to comment Share on other sites More sharing options...
[Ch...] Posted June 6, 2025 Share Posted June 6, 2025 sounds like he was testing by moving nominal position to confirm it would always center into relatively the same position every time... aka just keeping an eye on Calypso... making sure it does what its supposed be doing.... Link to comment Share on other sites More sharing options...
[Ma...] Posted June 6, 2025 Share Posted June 6, 2025 Please sign in to view this username. - oh - like modifying touch point coordinates sligthly and then checking results how much they differ. Thanks - i would think about that :-) Link to comment Share on other sites More sharing options...
[na...] Posted June 6, 2025 Author Share Posted June 6, 2025 Correct, I imagined this would somehow simulate measuring the work piece with non-perfect fixture. Which turned out, in this case there is no need for it to be perfect. Link to comment Share on other sites More sharing options...
