[Jo...] Posted June 6 Share Posted June 6 We keep our inspection files on the network (which I know is not suggested), we recently had some network issues that seemed to break some of our programs that were open at the time. We brought back the archived versions and this appeared to fix the issue except for one program. This program will no longer open on any machine or simulation seat and neither will the archived versions. We only get a generic error message that says "Measurement Plan could not be loaded" and where screen shows what is being measured it stays at "Loading meas. plan XXX (8/9)". I have tried going further back in the archive as well as comparing the files inside the folder for any red flags but cant find anything. Any help would be greatly appreciated. Link to comment Share on other sites More sharing options...
[Je...] Posted June 9 Share Posted June 9 Try extracting the "inspection" file from the inspection folder and opening it separately within CALYPSO. This will force CALYPSO to ignore any of the other files that may have been corrupted due to network problems and create them fresh. This will cause some settings to be erased/reset but it will give you a starting point. Link to comment Share on other sites More sharing options...
