[Is...] Posted June 10, 2025 Share Posted June 10, 2025 Trying to clean up our gear pro system / actuals, does anyone know how gear pro creates the file # for reports? Is it random or is there a sequence to it? Thank You Link to comment Share on other sites More sharing options...
[Ch...] Posted June 10, 2025 Share Posted June 10, 2025 Great question, it appears random but I am not sure, at any rate, you should be able to see the date/time of the file and clean up/archive based on that. Link to comment Share on other sites More sharing options...
[Ky...] Posted June 10, 2025 Share Posted June 10, 2025 I do not know for certain, but I believe I heard it is the Unix timestamp when it was created. the (one) file I tried seemed to be reasonably close to it. 1 Link to comment Share on other sites More sharing options...
[Ch...] Posted June 11, 2025 Share Posted June 11, 2025 Kyle, thank you again sir, probably correct here. Gear Pro is not that old, I can't imagine why they went with UNIX.... 😄 Link to comment Share on other sites More sharing options...
[Ky...] Posted June 11, 2025 Share Posted June 11, 2025 Unix epoch timestamps are actually pretty standard in programming, so from a programming context it makes perfect sense. 2 Link to comment Share on other sites More sharing options...
[Is...] Posted June 12, 2025 Author Share Posted June 12, 2025 It correlates to Unix, thank you both! Link to comment Share on other sites More sharing options...
