File Numbering System
Trying to clean up our gear pro system / actuals, does anyone know how gear pro creates the file # for reports? Is it random or is there a sequence to it?
Thank You
Great question, it appears random but I am not sure, at any rate, you should be able to see the date/time of the file and clean up/archive based on that.
I do not know for certain, but I believe I heard it is the Unix timestamp when it was created. the (one) file I tried seemed to be reasonably close to it.
Kyle, thank you again sir, probably correct here.
 Gear Pro is not that old, I can't imagine why they went with UNIX.... 😄
Unix epoch timestamps are actually pretty standard in programming, so from a programming context it makes perfect sense.
