[ji...] Posted June 11 Share Posted June 11 Link to comment Share on other sites More sharing options...
[Cl...] Posted June 11 Share Posted June 11 Looks like you figured it out. Link to comment Share on other sites More sharing options...
[Ch...] Posted June 11 Share Posted June 11 his picture shows the far end going to about only the center though. sometimes you have to close and reopen to get the arrows to correlate. I believe it should be Max/Max in this case, but if it's not giving you correct nominal try minimum for one. Make sure arrow correlate after closing characterstic. Link to comment Share on other sites More sharing options...
[DW...] Posted June 11 Share Posted June 11 Please sign in to view this quote. Please sign in to view this username. Change the front to minimum. Leave the back to maximum. The min and max values are from the features in their respective axis. So you would want the minimum Y coordinate of the front feature, and the maximum Y coordinate of the back feature. Link to comment Share on other sites More sharing options...
[DW...] Posted June 11 Share Posted June 11 Please sign in to view this quote. Please sign in to view this username. I believe it appears that way based on the viewing angle. The back is at maximum like it should be... but I do agree the Caliper Distance can get wonky visually sometimes, forcing a close and reopen. Link to comment Share on other sites More sharing options...
[Ri...] Posted June 12 Share Posted June 12 Unless there is some specific view/alignment that the drawing dictates, I think that the Polar Caliper Distance would be better suited for this. Link to comment Share on other sites More sharing options...
[Je...] Posted June 12 Share Posted June 12 Evaluating these features as cylinders rather than circles will provide a defendable result. Your characteristic shall be a cartesian distance. Link to comment Share on other sites More sharing options...
[DW...] Posted June 13 Share Posted June 13 Please sign in to view this quote. Please sign in to view this username. Cartesian distance is a center to center measurement, not what is needed here. Link to comment Share on other sites More sharing options...
