View Actuals of a specific pattern index
When using patterns, when you click on the feature or characteristic it defaults to showing index #1.  Is there a way to show a specific index number?
I am aware of how to change the nominals and actuals that show up visually, but i would like to update the feature pane to show the actuals and nominals for a specific index.   My workflow for troubleshooting measurements involves peeking at the actuals and its quite inconvenient to have to generate a PiWeb report to see the actual numbers.
It appears when double clicking a feature or characteristic that the first available pattern index is always shown. I dont see a way to select others
If I'm understanding the problem correctly, my first thought is to bring a circle from the features dropdown, and recall the feature points from the index to be analyzed.
  • Like! 1
select feature right click, show actuals, there should be a list for each index or "all" or none if the feature is patterned.
This is the only solution ive found to show the actual number without having to generate a report.  It makes troubleshooting slower than we are used to, but still possible
I thought you meant to see the actual for a specific index, for what you mentioned, yes I agree with the above, or simply use a results element/PCM, etc.
Only thing i found was using basic features ( i tried circle ).
While using empty feature of same type you can recall feature and select which index. Although it will report actuals as nominals if you have measured it.
Can not be done on curves - there is only recall measured points.
Edited
