[Jo...] Posted Monday at 04:01 PM Share Posted Monday at 04:01 PM When using patterns, when you click on the feature or characteristic it defaults to showing index #1. Is there a way to show a specific index number? I am aware of how to change the nominals and actuals that show up visually, but i would like to update the feature pane to show the actuals and nominals for a specific index. My workflow for troubleshooting measurements involves peeking at the actuals and its quite inconvenient to have to generate a PiWeb report to see the actual numbers. Link to comment Share on other sites More sharing options...
[DW...] Posted Monday at 04:22 PM Share Posted Monday at 04:22 PM Please sign in to view this quote. Please sign in to view this username. is it always the same index number? Link to comment Share on other sites More sharing options...
[Jo...] Posted Monday at 06:24 PM Author Share Posted Monday at 06:24 PM It appears when double clicking a feature or characteristic that the first available pattern index is always shown. I dont see a way to select others Link to comment Share on other sites More sharing options...
[Ha...] Posted Monday at 08:35 PM Share Posted Monday at 08:35 PM If I'm understanding the problem correctly, my first thought is to bring a circle from the features dropdown, and recall the feature points from the index to be analyzed. 1 Link to comment Share on other sites More sharing options...
[Ch...] Posted Monday at 11:08 PM Share Posted Monday at 11:08 PM select feature right click, show actuals, there should be a list for each index or "all" or none if the feature is patterned. Link to comment Share on other sites More sharing options...
[Jo...] Posted 15 hours ago Author Share Posted 15 hours ago >If I'm understanding the problem correctly, my first thought is to bring a circle from the features dropdown, and recall the feature points from the index to be analyzed. This is the only solution ive found to show the actual number without having to generate a report. It makes troubleshooting slower than we are used to, but still possible Link to comment Share on other sites More sharing options...
[Ch...] Posted 5 hours ago Share Posted 5 hours ago I thought you meant to see the actual for a specific index, for what you mentioned, yes I agree with the above, or simply use a results element/PCM, etc. Link to comment Share on other sites More sharing options...
[Ma...] Posted 2 hours ago Share Posted 2 hours ago (edited) Only thing i found was using basic features ( i tried circle ). While using empty feature of same type you can recall feature and select which index. Although it will report actuals as nominals if you have measured it. Can not be done on curves - there is only recall measured points. Edited 2 hours ago Link to comment Share on other sites More sharing options...
