[Se...] Posted June 17 Share Posted June 17 I recently updated to windows 11 and lost my configuration files, essentially having to start from the ground up. (luckily my part programs were backed up) When I load in one of the old programs (same version of calypso 7.6.00) the "tolerancing method" block in the characteristic is blank, and even if the tolerance and the result is correct the characteristic still fails. I am hoping I missed something. See the image below: Link to comment Share on other sites More sharing options...
[Ch...] Posted June 17 Share Posted June 17 Is it possible that you typed in these upper/lower tolerance values before clicking "OK" and the color behind just hasn't had a chance to update? Typically the red/green color indicator won't update until the window is closed. Link to comment Share on other sites More sharing options...
[Se...] Posted Monday at 03:05 PM Author Share Posted Monday at 03:05 PM It is a proven program that I have been running for over a year. This issue has impacted every program since updating. When I re-type the actual tolerance it turns green and reads it properly. I am hoping to avoid having to do that on all of the characteristics on all of the programs that are on this machine. Link to comment Share on other sites More sharing options...
[Da...] Posted Monday at 03:19 PM Share Posted Monday at 03:19 PM Have you checked your round off numbers to be sure they didn't change? Link to comment Share on other sites More sharing options...
[Ri...] Posted Monday at 04:59 PM Share Posted Monday at 04:59 PM Try using "Min/Max" for your tolerance and see if it becomes stable. Nominal .27600 Min .27100 Max .28100 (For bug testing). Link to comment Share on other sites More sharing options...
[To...] Posted Monday at 05:06 PM Share Posted Monday at 05:06 PM Are you able to re-select the tolerance mode? It appears that it is trying to hold you to an actual value between .005 and -.005, i.e. Max/Min Link to comment Share on other sites More sharing options...
[Ri...] Posted Monday at 05:11 PM Share Posted Monday at 05:11 PM Please sign in to view this quote. I was leading to that but my broken is english today...😂 1 Link to comment Share on other sites More sharing options...
[Se...] Posted Monday at 08:41 PM Author Share Posted Monday at 08:41 PM Please sign in to view this username. Round-off presets: round-off measure .0001" , Mode: Automatic from nom. Geometry, Tolerance: Number scale Please sign in to view this username. Please sign in to view this username. Reselecting the tolerance mode works except that it will also change the actual tolerance. Once I re-type the tolerance it works. (but doing this on every program would be very tedious) I screen recorded a vid, I hope y'all can view it. Thanks guys. Recording 2025-06-23.zip Link to comment Share on other sites More sharing options...
[Se...] Posted Monday at 09:01 PM Author Share Posted Monday at 09:01 PM ***Just realized I missed a patch when I redownloaded Calypso. I will do that and check back*** Link to comment Share on other sites More sharing options...
