[Op...] Posted June 18, 2025 Share Posted June 18, 2025 I've found that I can export raw datum measurements, however the surface of interest always has to be exported to an alignment. Is it possible to get the surface measurement exported just in raw machine coordinates? Link to comment Share on other sites More sharing options...
[Ha...] Posted June 18, 2025 Share Posted June 18, 2025 You many be able to bring in a secondary alignment and set it to the CMM coordinate system, set the surface to the alignment, and export the points. However, I have not tried this before so I cannot say if this will work as intended. 1 Link to comment Share on other sites More sharing options...
