[Da...] Posted June 19, 2025 Share Posted June 19, 2025 Hi all, I'm developing an add-on using ZEISS Inspect 2023 SP5 and trying to automate importing of mesh (.g3d) and CAD (.stp) files. Despite the official API documentation and GitHub examples referencing commands like: gom.script.sys.import_stp_file(file=...) gom.script.sys.import_gom_file(file=...) I receive this runtime error: GScriptErr-0006: Error executing script "gom.script.sys.import_stp_file" is not a valid command name. I'm running this inside the Add-On Editor (via play button). My license shows gom-inspection-pro, and files import fine manually. Question: Are these functions supported in the Add-On environment? Or are they limited to macro templates or another scripting context? Any insight is appreciated — trying to determine whether to pivot or work around it via .zininspect projects. Link to comment Share on other sites More sharing options...
[Na...] Posted June 20, 2025 Share Posted June 20, 2025 Hi David, when recording the imports the you will get gom.script.sys.import_g3d ( files=...) gom.script.sys.import_cad (files=...) Can you link me to the example where the commands you mentioned were used? Maybe they worked in a former version. Nanno Link to comment Share on other sites More sharing options...
[Da...] Posted June 23, 2025 Author Share Posted June 23, 2025 Hi Nanno, Thank you again for your help with the import commands — that change did the trick! I’m currently working on a research project as part of a summer internship where I’m developing an add-on inside ZEISS INSPECT 2023 SP5 to automate defect analysis. The pipeline includes importing mesh and CAD files, performing best-fit alignments, creating sections, and eventually generating deviation-based labels for inspection. With the import step now functional, I’m moving on to alignment scripting and then sectioning logic. I have about 5 weeks left in my internship (through July 28), and to make the most of it, I’d love to know if there’s a centralized or more up-to-date source where I can find supported command names for the Add-On scripting environment. Having that would really help me iterate faster and reduce trial-and-error time. If you have any suggestions or links, I’d greatly appreciate it. Best, David Olorunpoju-Essang Link to comment Share on other sites More sharing options...
[Da...] Posted June 23, 2025 Author Share Posted June 23, 2025 Thanks again, Nanno! I’ve now successfully imported both CAD and mesh using gom.script.sys.import_cad and gom.script.sys.import_g3d. However, the imported CAD appears in the project but is not automatically assigned to the mesh part. I tried using gom.script.sys.assign_nominal_elements_to_part, but it seems unsupported in the Add-On context. Is there a valid way to programmatically assign nominal elements (CAD) to a mesh-based part within the Add-On scripting environment? Any guidance or a working example would really help. Thanks again! # -*- coding: utf-8 -*- import gom # Define full paths to your files cad_path = r"C:\Users\olorunpojuessangd\Desktop\Purdue University Project\GOM Training Object CAD.stp" mesh_path = r"C:\Users\olorunpojuessangd\Desktop\Purdue University Project\GOM Training Object Mesh 2.g3d" # Step 1: Import CAD try: gom.script.sys.import_cad(files=[cad_path]) print("✅ CAD import successful.") except Exception as e: print(f"❌ CAD import failed: {e}") # Step 2: Import Mesh try: gom.script.sys.import_g3d(files=[mesh_path]) print("✅ Mesh import successful.") except Exception as e: print(f"❌ Mesh import failed: {e}") # Step 3: Assign imported CAD to the first part in project try: if len(gom.app.project.parts) == 0: print("⚠️ No part found after mesh import.") else: part = gom.app.project.parts[0] # Find the imported nominal CAD element imported_nominals = gom.app.project.nominal_elements if not imported_nominals: print("⚠️ No nominal CAD elements found.") else: # Assign nominal CAD to part gom.script.sys.assign_nominal_elements_to_part( part=part, nominal_elements=imported_nominals ) print(f"✅ Assigned {len(imported_nominals)} CAD elements to part '{part.name}'.") except Exception as e: print(f"❌ Failed to assign CAD to part: {e}") Link to comment Share on other sites More sharing options...
[Na...] Posted June 24, 2025 Share Posted June 24, 2025 Hi, this was the code I got when recording the import: # -*- coding: utf-8 -*- import gom gom.script.sys.import_cad ( files=['C:/Training/Inspection 2023/Training Data/Raw Data/Nominal/ZEISS Training Object CAD.stp'], filter='ALL', import_fta=True, import_mode='clipboard', repair_mode=5, triangulation_mode='tessellation', triangulation_presets={'manual_refine_borders': True, 'triangulation_mode': 'medium'}) gom.script.part.add_elements_to_part ( delete_invisible_elements=True, elements=[gom.app.project.assembly_tree['Z_TRAINING_OBJECT_ASM_ASM 2']], import_mode='new_elements', part=gom.app.project.parts['Part 1'], triangulation_parameter={'manual_refine_borders': True, 'triangulation_mode': 'medium'}) Part 1 existed and contains a mesh only. There is no list with all commands but you can always record your actions and generalize them afterwards. Adding elements to parts is described here: ZEISS INSPECT Python API Introduction — App Development Documentation I don't know your project, but in many cases it is not necessary to script element creations or alignments, because this could be covered by the parametric of the software by using a project template Nanno Link to comment Share on other sites More sharing options...
