[ma...] Posted Tuesday at 07:24 AM Share Posted Tuesday at 07:24 AM Good morning, how do I create a sphere tangent to a measured cone? Thanks Link to comment Share on other sites More sharing options...
[Ma...] Posted Wednesday at 03:57 PM Share Posted Wednesday at 03:57 PM You can make a theoretical sphere and drop it in the cone or create a cone calculation to achieve the point of engagement. Then use a result element to add the formula to calculate the height of the sphere. Link to comment Share on other sites More sharing options...
[Ma...] Posted Wednesday at 04:06 PM Share Posted Wednesday at 04:06 PM (edited) This would be easier with 2 lines and tangential element with defined radius. Or with calculation you can do something like this. calculate diameter on sphere from cone angle make theoretical cylinder of this diameter in axis of cone do intersection of cylinder and cone shell place theoretical sphere in resulted circle and calculate adjustment for cone angle Edited Wednesday at 04:10 PM Link to comment Share on other sites More sharing options...
[Ch...] Posted Wednesday at 04:11 PM Share Posted Wednesday at 04:11 PM highly suggest buying a probe with this exact gage ball size if possible, we do a lot of similar dimensions. 2 Link to comment Share on other sites More sharing options...
[Jo...] Posted 21 hours ago Share Posted 21 hours ago Over Ball Height.pdf Here is a guide for obtaining the over ball height I created years ago. There may be other easier methods to accomplish this. This is what worked for me. Link to comment Share on other sites More sharing options...
[Jo...] Posted 20 hours ago Share Posted 20 hours ago Just my two cents, but using a stylus probe the size needed to simulate a gage diameter is not the same as a gage sphere. Stylus probes do have size tolerance and may not be the exact diameter called out on the print (of course, it's probably pretty close). This method will get you a close number depending on the diameter size error. This error might be negligible for your tolerances. Link to comment Share on other sites More sharing options...
