[Ry...] Posted June 26, 2025 Share Posted June 26, 2025 Hello all, I just recently started sometimes experiencing this issue after a measurement is completed. It happens frequently & it doesn't seem to have a science behind it - it might not happen an entire shift and sometimes it happens after every 5 parts measured. It either causes my autorun program to stop entirely - or if I am measuring a part in the window with the CAD model, it does not automatically increase the sample number for the next part - so if I do not catch this, it overwrites my PDF, excel and measured points file - causing me to have to remeasure the part entirely if I do not have my SPC software QC Calc open. Has anyone ever experienced this or knows a fix? Link to comment Share on other sites More sharing options...
[Sv...] Posted June 27, 2025 Share Posted June 27, 2025 Hatte ich auch. Deutet auf die Grafikkarte hin. Ich habe einen Beitrag im Forum gefunden mit einer Lösung die zumindest bei mir Funktioniert. Desktop Rechtsklick mit der Maus. Bei Win11 auf weiter Optionen->Nvidia Systemsteuerung->3D-Einstellungen verwalten->dann rechts im dropdown Autodesk Motion Builder - compatible auswählen. Dies hat bei mir zum ende dieses Fehlers geführt. Link to comment Share on other sites More sharing options...
[Mi...] Posted June 27, 2025 Share Posted June 27, 2025 https://qualityforum.zeiss.com/topic/7388-system-error-nach-prüfplanschließung/?do=findComment&comment=31156 Link to comment Share on other sites More sharing options...
[Ab...] Posted June 27, 2025 Share Posted June 27, 2025 https://portal.zeiss.com/knowledge-base?id=1596796 Link to comment Share on other sites More sharing options...
