[Má...] Posted May 31, 2021 Share Posted May 31, 2021 Hello All, I would like to start the program and one of the script by using external python script. I could open the software with the following: ----------- filepath = 'C:/Program Files/GOM/2020/bin/gom_inspect.exe' import os os.startfile(filepath) ----------- Could you give advice about starting a script with external python? BR, Máté Link to comment Share on other sites More sharing options...
[Th...] Posted June 3, 2021 Share Posted June 3, 2021 There is an "-eval" command line parameter which can be used to run scripts in GOM Software by importing them. Lets's assume you have such a script called my_script in GOM Software: Than you can run it by command line parameter from another script this way: import subprocess subprocess.call ('"C:/Program Files/GOM/2020/bin/gom_inspect.exe" -eval "import my_script"') Link to comment Share on other sites More sharing options...
[Má...] Posted June 3, 2021 Author Share Posted June 3, 2021 Please sign in to view this quote. Link to comment Share on other sites More sharing options...
[ca...] Posted June 23, 2022 Share Posted June 23, 2022 Hello, I am using Gom Suite (2021 version). I need to open blade inspect pro after opening suite. Could you please share updated code for 2021 version? Thanks, Canset Link to comment Share on other sites More sharing options...
[Má...] Posted September 30 Author Share Posted September 30 Hello, How is it look like in SW 2023? Start of the program is ok, but how can I start a script inside our program? Best regards, Máté Link to comment Share on other sites More sharing options...
[Ma...] Posted Friday at 08:40 AM Share Posted Friday at 08:40 AM Hi, you can find the information here: Software and script starting options — App Development Documentation Best regards, Matthias 1 Link to comment Share on other sites More sharing options...
