[Sh...] Posted July 1, 2025 Share Posted July 1, 2025 Good morning, I noticed when using (readActualWPTemperature()* 1.8) + 32) for pulling the actual Temperature using Result Element/PCM, it does not work well with Measure Points and Planner. Does anyone have any suggestions for recording the actual as a number that can be used with Measure Points? Thanks Link to comment Share on other sites More sharing options...
[Ch...] Posted July 1, 2025 Share Posted July 1, 2025 Shawn, I thought of this as well, you mean when you recall a test, the PCM will read the temp as it is now, correct? A good option might be to output it to a file instead so you will have all temps by date/time and or S/N. If you mean a way that will automagically recall the value with the .zmp everytime; maybe try using the temp as a VARiable in for example a circle diameter with a formula and PCM ? Link to comment Share on other sites More sharing options...
