[Gu...] Posted July 1, 2025 Share Posted July 1, 2025 We have a new T-Scan Hawk 2. We wanted to start a scan on a large object using the satellite scan method. When I start the template, it ask me for the HyperScale files, which were not preloaded on the laptop that came with it. Is there anywhere on the computer where I would point Inspect to locate the files for the two HyperScales? Link to comment Share on other sites More sharing options...
[Pa...] Posted July 2, 2025 Share Posted July 2, 2025 They are located on the USB-stick that you should have got with your scanner. Just plug in the stick and open Inspect. Go to [Preferences] in the [Edit]-dropdown menu. You import them in the expandable menu [Templates] - [HyperScales]. After that is done, then just remove the USB-stick. Link to comment Share on other sites More sharing options...
