[Lo...] Posted July 14, 2025 Share Posted July 14, 2025 Hello Zeiss/Calypso world I turned on additional report on some profiles to clarify/expand the data being fed back to production. I have noticed that the X.Y.Z nominals recalculate every run, producing new nominals for each run. This has led to confusion among the team members I am giving the data to. Does anyone have an explanation for this? profile nominals.docx 1 Link to comment Share on other sites More sharing options...
[Ri...] Posted July 14, 2025 Share Posted July 14, 2025 I assume you are scanning, so this is to be expected because it is reporting the nominals of the largest deviation, which is going to change from part-to-part and run-to-run. If this is an issue, maybe you could instead take discrete points, and report their profile. Then the nominal will never change. 2 1 Link to comment Share on other sites More sharing options...
[Lo...] Posted July 18, 2025 Author Share Posted July 18, 2025 Please sign in to view this quote. Thank you for the clarification! Link to comment Share on other sites More sharing options...
[Da...] Posted July 19, 2025 Share Posted July 19, 2025 The min/max points are never in the same position on the profile because each part has a different geometry and profile deviations after machining. Link to comment Share on other sites More sharing options...
