[Ju...] Posted July 17, 2025 Share Posted July 17, 2025 (edited) Hallo everyone, when i scan an area in an automatic script and then polygonize it, it always takes a while. Is it possible to speed up this procedure, e.g. by running it in the background? With kind regards, Jure Baloh Edited July 17, 2025 Link to comment https://qualityforum.zeiss.com/topic/23959-faster-polygonisation-of-the-surface/ Share on other sites More sharing options...
[DW...] Posted July 17, 2025 Share Posted July 17, 2025 Please sign in to view this quote. Please sign in to view this username. Are you using a mechanical hard drive? Switch to a solid state drive with faster read/write times. Check out SSK brand on Amazon. Link to comment https://qualityforum.zeiss.com/topic/23959-faster-polygonisation-of-the-surface/#findComment-135317 Share on other sites More sharing options...
[Ja...] Posted July 17, 2025 Share Posted July 17, 2025 Are you using an automation device? If so Kiosk is the easier answer to handle background polygonisation Alternatively could just scan during the day and post process in a batch overnight. Link to comment https://qualityforum.zeiss.com/topic/23959-faster-polygonisation-of-the-surface/#findComment-135337 Share on other sites More sharing options...
