Putting labels on stylus systems
I was wondering if anyone had a good solution to adding physical lables onto their styli.  I have XXT so all the styli generally have 5mm carbon fiber extensions.  I could use the faithful label maker and print stickers but they peel and is not ideal so does anyone have anything better?
The end goal is for somone with next to zero cmm experience to be able to identify which is which (e.g. I have to remote in and tell the machine to manually pick up the stylus that it is holding because it forgot for some reason).
Almost all my stylus systems have a place in the storage bay. So, I label the bay holders. I've had operators remove styli for whatever reason and put them back in the wrong bay. We all know what happens then. I'll take it a step further. I also have a spreadsheet with an inventory of all the stylus systems we have by machine. The styli system as well as the individual styli within each system are identified by their name, i.e., Star_1/1.0_Y+/2.5_X+/1.5_Z-, etc. aa well as the direction each stylus is pointing when in the rack. That way if any of them break, I know which position to screw the replacement into. I've had operators crash and break all the styli on a system. So that (along) with a picture) can come in handy. As far as individual stylus systems that are manually loaded and don't have a position in the holder. I made a labeled holder for the base plate to set in.
The attached Excel macro file is how I track all Probe builds.
Use it as needed. 😁
The "Order Sheet" is where I place information for ordering. Clear it after every order.
XT and XTR have labels placed on the 20mm cube from the XT/XTR plate.
XXT has abbreviations written on the underside of the probe plate. Example: Combo80R would be abbreviated to C80R (R designates it is an RDS probe).
Master_Probe Builds workbook 2024.xlsm
Edited
  • Like! 2
