CAD Presentation settings, edit en mass.
Is there a magic button to edit all of my CAD Presentation settings at once?
Using Calypso v7.4.24
Currently I have to edit each individual CAD Presentation to enable plots and change the display of the Heat Map from Cylinders to Spheres.
There are over 100 in this particular program.
To add to this, it seems I can't change from Cylinders to Spheres. The software will not maintain the changes. 🤬
As far as i know there is no easy solution. Perhaps my next project could solve some issues.
When i need to redo this i will open and show view, then change what is needed ( factor ... ) then resave with same name.
I often have to click that on first creation, otherwise i don't have this CAD view in protocol. Perhaps lost bug.
CAD Presentation doesn't allow you to overwrite, it just says the "name already exists" with an OK button.
I was thinking that you made those steps:
  1. enable graphical evaluation of deviations
  2. selected characteristic
  3. rotated and positioned a view
  4. clicked "CAD presentation"
This should make a separate window with your stored view on deviations.
Or am i getting it wrong?
