[Ch...] Posted July 28, 2025 Share Posted July 28, 2025 Hello all, I am bringing this subject to the general forum from a PiWeb thread, although I tried using a suggestion from that thread. I want to add in several user defined fields header information to the Excel reports that are created in Calypso (not through PiWeb). Using a suggestion on the other thread, I found the user defined fields I needed, and made changes to the Excel template and INI files. Steps I took: 1. Made copies of original Characteristic .xlt and .xls files, and ReportINI .xls and .xlsx files for editing. 2. Added correct username fields to all 4 files for additional header info 3. Moved 4 original files to temporary folder 4. Placed 4 new modified files in excel_report folder, replacing the old ones. 5. Selected the new template in the Define Report tab and then ran the program. The new template with the new user defined field names shows up, but is empty of all data, including fields I didn't touch. I was pretty sure this would work but something is not clicking. Any thoughts? Appreciate any help. Thanks. C. Collins Link to comment https://qualityforum.zeiss.com/topic/24055-excel-report-user-defined-fields/ Share on other sites More sharing options...
[Lu...] Posted July 30, 2025 Share Posted July 30, 2025 Hello Chris, This article on the ZEISS Portal may help - Adding Custom Variables to Excel Reports. 1 1 Link to comment https://qualityforum.zeiss.com/topic/24055-excel-report-user-defined-fields/#findComment-135953 Share on other sites More sharing options...
[Ch...] Posted July 30, 2025 Author Share Posted July 30, 2025 Please sign in to view this quote. Lucas, Thank you so very much. That was a tremendous help, and it works now. 1 Link to comment https://qualityforum.zeiss.com/topic/24055-excel-report-user-defined-fields/#findComment-136025 Share on other sites More sharing options...
[Lu...] Posted July 30, 2025 Share Posted July 30, 2025 Please sign in to view this quote. Chris, You're very welcome. Glad to hear the article helped you work it out! Link to comment https://qualityforum.zeiss.com/topic/24055-excel-report-user-defined-fields/#findComment-136033 Share on other sites More sharing options...
[Ma...] Posted 1 hour ago Share Posted 1 hour ago Hello all, sadly when I try to open this link, I get the message: "This page does not exist". If somebody has the time to share what was discribed in this article, I would be really grateful. Matthias Link to comment https://qualityforum.zeiss.com/topic/24055-excel-report-user-defined-fields/#findComment-157460 Share on other sites More sharing options...
[na...] Posted 31 minutes ago Share Posted 31 minutes ago Please sign in to view this quote. Please sign in to view this username. I cannot believe the Knowledge Base problem is still not solved. Dear Carl ( Please sign in to view this username. ), when is the release date planned? Link to comment https://qualityforum.zeiss.com/topic/24055-excel-report-user-defined-fields/#findComment-157466 Share on other sites More sharing options...
