[Ro...] Posted July 30 Share Posted July 30 Hello everyone, Is there a way to perform a coordinate transformation in PCM? Example: Values in the basesystem X 0.05 mm Y 0.02 mm Z 0 mm Rx 160 µrad Ry 20 µrad Rz 2 µrad Coordinatesystem 1 transformation/rotation relative to the base system X -647 mm Y -227.306760 mm Z -310.933865 mm Rotation around X -1.292416 rad Rotation around Y 0 Rotation around Z 0 Is there a PCM Way to get the coodinate transformation as if i would change the coordinate system in the feature? Link to comment Share on other sites More sharing options...
[Ch...] Posted July 30 Share Posted July 30 More info here : https://qualityforum.zeiss.com/topic/23125-alternative-to-getpositioncmm-for-user-defined-coordinate-systems/ Link to comment Share on other sites More sharing options...
