Inspection status global für alle Programme anpassen?
Moin,
wir haben PCM. Ist es möglich alle Messprogramme mit dem PCM Befehl "inspectionToleranceState()" global an zupassen? Oder muss ich jedes Programm öffnen?
THX  🤘🏻
Question? IS this PCM already in each program? Or you would like to add it to each program now?
 If you would like to now add it, the easiest way is likely using inspection_end_pcm.txt    in your inspection directory, this should cover all programs in the directory.
  • Thank you! 1
Chris I want add it now
status=inspectionToleranceState()
 if status=="outOfTolerance" then
   setProtocolOutput("compactProtocol","print")
 endif
The reason : "We'd like to save paper as soon as possible, sorry, Stone Age."
We only want a printout if tolerance is violated.
I wish Zeiss would add a way to update 'all measurement plans' at once like one of the menu options says, however that setting only applies to 'open' measurement plans.
To do what you are asking (perhaps in the program Post PCM field) may require a unique code with with Notepad++ to directly edit the inspset file, etc.
You could simply paste this in Post settings of every program as well, how many programs do you have ??
I would reach out to Zeiss first for their recommendations.
Chris I´m with you. I have around 300-500 programs. 🤓 Then we have four CMM with FACS and five with AutoRun, it looks like job creation. At the start with PiWeb we only buy th small 10 GB version.
  • Like! 1
