abc alignment x value is different than true position x value
I have a drawing that asks for a x value of a feature and also a true position. (They should have made the x value s basic dimension) So I clicked the x value and got a value.
Then saw the true position callout and dimensioned true position with xz values.
I got a difference of .005 between the result of true position X value and the feature X value. Both base alignment and true position datums identical.
Also tried various evaluation methods and getting significant variation.
It does not make sense to me. Any thoughts??
Running Calypso 2024 on a Contura with VAST XT.  I've tried different evaluation methods and all show different results.
It depends on a feature. Non perpendicular plane, cylinder, maybe others will result in different value then just reporting X,Y,Z value.
Also often TP will report doubled value for cylindrical tolerance.
  • 3 weeks later...
Try to find topics on the forum, talking of how to pull value from position.
I know they exists, I just can't get it now.
Is it a diametric true position callout? If I'm understanding the question correctly, It could
have a third toleranced axis. I'd have to see the drawing to be sure.
