"Stack Projection"
This may be more of a GD&T-related question, but has anyone ever heard of this blueprint requirement ("stack projection") and/or programmed it in Calypso. To me, seems similar to projected tolerance zone...
My blueprint has a true position of a cylinder with a specified "stack projection"
Edited
definitely sounds like a 'projected tolerance zone' which calypso is capable of. You should see a small letter 'P' near the position tolerance inside a position characteristic.
  • 3 weeks later...
Your drawing, if complete, should reference an "interpretation of drawing" spec, or something similar. It is in this spec where you should (again, if everyone else has done their part) find definitions and interpretation guidance for any characteristic on the drawing (including this "stack projection").
