[An...] Posted August 4, 2025 Share Posted August 4, 2025 I have a qualification program that qualifies all of our styli in all of their respective positions. This program has worked well for a couple years but over the last few weeks it has started to skip random styli positions, It has done this on two different machines and each week seems to be a different styli and different position. All the program is doing is running the Zeiss qualification characteristic. Any suggestions on why it would skip certain positions? Thanks in advance Andrew Link to comment Share on other sites More sharing options...
[Ke...] Posted August 4, 2025 Share Posted August 4, 2025 (edited) What version of Calypso are you running? Is the program stored locally or on a network? Have there been any other changes that may align with the timing of this? Edited August 4, 2025 Link to comment Share on other sites More sharing options...
[An...] Posted August 5, 2025 Author Share Posted August 5, 2025 We are running Calypso 7.6.20 2023 service pack 5. Program is stored on a network drive. No system changes that I can think of. Link to comment Share on other sites More sharing options...
[Ke...] Posted August 5, 2025 Share Posted August 5, 2025 The program being stored on a network may be influencing this, as both systems may be writing to an actuals file and causing issues. I've attached a knowledgebase article here regarding storing programs on network https://portal.zeiss.com/knowledge-base?id=552028 1 Link to comment Share on other sites More sharing options...
[Ow...] Posted August 5, 2025 Share Posted August 5, 2025 For what it's worth, I had this happen on a Duramax CMM a couple years ago that was not on a network at all. I don't know what happened, but I had to recreate the qualification characteristic on the stylus system that wasn't calibrating to get it to work . Link to comment Share on other sites More sharing options...
[Ch...] Posted August 7, 2025 Share Posted August 7, 2025 Is it possible that the styli deviation was too large? This isn't displayed in automatic mode, and the values are skipped. Link to comment Share on other sites More sharing options...
[An...] Posted August 7, 2025 Author Share Posted August 7, 2025 Please sign in to view this username. I will try that, seems very Calypso Please sign in to view this username. I went back through a few months of qualification data, If the deviation is too large it will still update the date even tho the styli failed. Link to comment Share on other sites More sharing options...
[To...] Posted August 7, 2025 Share Posted August 7, 2025 If the reference sphere shaft rotation/tilt angles are in a position that prevents clear access for a stylus, it will skip that stylus. 1 Link to comment Share on other sites More sharing options...
[An...] Posted August 12, 2025 Author Share Posted August 12, 2025 UPDATE: When a styli is dirty, it is not updating the date or sigma value in the styli management window. If I clean the styli and run it again it will update the date and sigma value. I did update the service pack to 7.6.20 Service pack 5 around the time this started, thinking that could be the cause? Would rather not roll back service packs, is there a setting related to storing/updating qualification data? Link to comment Share on other sites More sharing options...
