[Ri...] Posted August 5, 2025 Share Posted August 5, 2025 Looking for a stripped-down CAD model of the VAST XXT sensor. I will most likely 3D print this. We have a multi sensor setup and I need to have a protective case made to fit the sensor. Zeiss left a protective case for the XXT sensor, but nothing as an assembled unit. The model would need to be as shown in the image. Link to comment Share on other sites More sharing options...
[Ri...] Posted August 5, 2025 Share Posted August 5, 2025 Please sign in to view this username. Could you not use the STL from Stylus System Creator? RDS_Vast XXT.Visualization.zip Link to comment Share on other sites More sharing options...
[Ri...] Posted August 5, 2025 Author Share Posted August 5, 2025 I am working on an STL from SSC, it needs a lot of interior cleanup. Difficult to do with an STL. Link to comment Share on other sites More sharing options...
[No...] Posted August 6, 2025 Share Posted August 6, 2025 Please sign in to view this quote. Are you implying you can read and convert the proprietary 3D data from an SSC file? Link to comment Share on other sites More sharing options...
[Ri...] Posted August 6, 2025 Author Share Posted August 6, 2025 Please sign in to view this quote. I want to 3D print to make an impression in a protective case, the interior has miscellaneous items that do not need printed, and I was able to remove some of that. Link to comment Share on other sites More sharing options...
[Ji...] Posted August 6, 2025 Share Posted August 6, 2025 I could reverse engineer it it if you send me the stl. I use Geomagic DesignX 1 Link to comment Share on other sites More sharing options...
[Ri...] Posted August 6, 2025 Share Posted August 6, 2025 Please sign in to view this quote. You can directly export the STL from SSC inside of the options. 🙂  As for the VFF files, I have found no way to use them. The same with the .fct files. 1 Link to comment Share on other sites More sharing options...
[No...] Posted August 7, 2025 Share Posted August 7, 2025 Please sign in to view this quote. Oops, I didn't know that! Thanks! Link to comment Share on other sites More sharing options...
[Ow...] Posted August 11, 2025 Share Posted August 11, 2025 By Richard Stanich , Have you got a 3D scanner and that would create an STL quickly? You can get them really cheap now compared to a few years ago. Different scanners for different applications , optical, laser, etc. 1 Link to comment Share on other sites More sharing options...
[Ri...] Posted August 11, 2025 Author Share Posted August 11, 2025 I managed to get an STL thru SSC and printed. The printed model should work fine to make an impression for a shock proof case. Thanks for all the help. Link to comment Share on other sites More sharing options...
