PCM on non PCM machine
Hi
Just a quick question, is it possible to run programs with PCM programming on machines without PCM option and will Calypso use the PCM programming ?
Hi Martin,
as far as I know, only simple formulas work in the measurement elements. Proper PCM commands don't work, which means the program isn't running!
Yes. A PCM program will run on a CMM that doesn't have a PCM license. You can't access or do any editing of the PCM.
Edited
Thank you for the reply.
I am trying to see if PCM is something worth while to add on. We are expanding our CMM operations, but the cost to add PCM for each machine can stack up very quickly.
