Holes in thinner plastic scans
Is there a magic formula for scanning thinner plastic samples, without ending up with holes in the mesh? I seem to go back and forth in troubleshooting this issue. Less kV, more exposure and more image averaging seem to work on some projects, more kV with less exposure works better at other times. Struggling with a project currently, no matter the settings, seem to be having issue getting decent polygonization. Have attempted to utilize multiple variations of pol. settings as well. Have as much angle on the sample as I can manage. I'm left wondering if there was a "standard" setting to begin with regarding.
Thanks as always to the group for any assist.
 I have scanned A LOT of small plastic samples of all densities with our Metrotom 6 Scout. Your machine should be able to handle this just fine. Is "Use reliable surfaces only" unchecked? What does your volume look like (any problems visible)? What software are you using? Make sure beam hardening correction is off. When you double click the volume, a menu on the right side of the screen pops out. Go to "Display" and change your absorption length to a smaller number to increase the amount of material visible in the volume.
Volume has a lot of thin areas as well. I will look at the Metrotom, I have not purposefully enabled beam hardening. I had not tried/ was unaware of the absorption length setting, will definitely give that a try, appreciate the suggestions, will report back on results!
Posted (edited)
I'm using Zeiss Inspect 2025----beam hardening is off----- reliable surfaces remains unchecked-----the absorption length is interesting, played around with it, did seem to fill in a bit, but ultimately this particular sample was pushing the boundaries of volume limitation, so I could not get enough angle on the sample. resigned to scanning and capturing what I could with more angle solved the problem here. It's likely that there is no getting around utilizing a substantial angle for shorter path, is what this scan issue has seemingly shown.
Appreciate the help as always, this is a great spot for learning these systems
 Can you elaborate on the bold portion?
  • 3 weeks later...
Hey DWC, the bolded portion shown explains that adding more angle to my sample, so that there is a shorter path for the X ray to travel through, helped in this instance. The sample was large enough to have barely fit into my scanner's available capture window. When I added more angle to the sample (removing a lengthier path of a flat surface, the scan captured more successfully.
 I understand. Do you know how to use vertical view extension for parts that are taller than your max view window? It's very useful.
Yes, I use both horizontal extension, and vertical stitch/ merge frequently. There is always something someone wants to scan that is just outside of our practical volume allotment, keep tellin them we need to buy a larger unit 🙂 !
