[Is...] Posted August 7, 2025 Share Posted August 7, 2025 I am qualifying ring gauges and was wondering if it was possible to include a characteristic that will take and report the delta from the max/min actual diameters and report that. Thx! Link to comment https://qualityforum.zeiss.com/topic/24157-qualifying-ring-gauges/ Share on other sites More sharing options...
[Cl...] Posted August 7, 2025 Share Posted August 7, 2025 (edited) Open a Result Element and enter this formula. I'm not at Calypso right now to try it, but I think this will work. You will have to change the evaluation for each cylinder characteristic. abs( getActual("Diameter_Cylinder1a").actual- getActual("Diameter_Cylinder1b").actual) Edited August 7, 2025 Link to comment https://qualityforum.zeiss.com/topic/24157-qualifying-ring-gauges/#findComment-136469 Share on other sites More sharing options...
[Is...] Posted August 7, 2025 Author Share Posted August 7, 2025 I tweaked this for what I wanted and it worked, Thank you! 1 Link to comment https://qualityforum.zeiss.com/topic/24157-qualifying-ring-gauges/#findComment-136473 Share on other sites More sharing options...
