[Fe...] Posted August 15, 2025 Share Posted August 15, 2025 Help! How do I use Python to control GOM INSPECT, quickly export STL files, import STL files from a folder into a project template, automatically refresh reports, and save PDF and CSV files? Link to comment Share on other sites More sharing options...
[DW...] Posted August 15, 2025 Share Posted August 15, 2025 Please sign in to view this quote. Please sign in to view this username. Go into the Add-Ons menu, and click on Add-on Editor. You might need to make a template folder, then you will see the scripting area to the right. Record a macro and do all of the things you stated. Then tweak the macro using Python syntax or feed it into GPT. Link to comment Share on other sites More sharing options...
[Ri...] Posted August 15, 2025 Share Posted August 15, 2025 (edited) https://zeissiqs.github.io/zeiss-inspect-addon-api/2025/howtos/python_api_introduction/python_api_introduction.html Here is the documentation. Depending on how automated of a solution you want will dictate how easy this is to implement. Here is a script for importing files, converting them to STEP, and then exporting them. # -*- coding: utf-8 -*- import gom from PyQt5.QtWidgets import QApplication, QFileDialog import sys import os app = QApplication(sys.argv) # Set default folder path default_folder = r"" file_path, _ = QFileDialog.getOpenFileName(None, "Select an STL file", default_folder, "STL Files (*.stl)") if not file_path: print("No file selected. Operation canceled.") sys.exit() try: gom.script.sys.import_stl( bgr_coding=True, files=[file_path], geometry_based_refining=False, import_mode='clipboard', length_unit='mm', stl_color_bit_set=False, target_type='mesh' ) gom.script.part.create_new_part(name='Part') print("Imported Actual Elements:") for element in gom.app.project.clipboard.actual_elements: print(" -", element) gom.script.part.add_elements_to_part( delete_invisible_elements=True, elements=[el for el in gom.app.project.clipboard.actual_elements], import_mode='new_elements', part=gom.app.project.parts['Part'] ) gom.script.sys.switch_to_mesh_editing_workspace() MCAD_ELEMENT = gom.script.mesh.automatic_cad_surface_from_mesh( merge=True, mesh=gom.app.project.parts['Part'].actual, name='CAD group 1', number_of_quads=100000, preview_type=1 ) step_folder = r"" os.makedirs(step_folder, exist_ok=True) filename = os.path.splitext(os.path.basename(file_path))[0] step_export_path = os.path.join(step_folder, f"{filename}.step") print("Nominal Elements for STEP Export:") for el in gom.app.project.clipboard.nominal_elements: print(" -", el) gom.script.sys.export_step( elements=[el for el in gom.app.project.clipboard.nominal_elements], file=step_export_path ) print(f"STEP file exported to {step_export_path}") gom.script.cad.delete_element( elements=gom.ElementSelection({'category': ['key', 'elements', 'is_element_in_clipboard', 'True', 'explorer_category', 'nominal', 'object_family', 'cad']}), with_measuring_principle=True ) print("Process completed successfully!") except Exception as e: print(f"❌ Error occurred: {e}") Edited August 15, 2025 Link to comment Share on other sites More sharing options...
[Fe...] Posted August 18, 2025 Author Share Posted August 18, 2025 Please sign in to view this username. Thank you for sharing, but since I have no experience with this operation and am unsure how to modify it using Python, I may not be able to proceed. Link to comment Share on other sites More sharing options...
[Fe...] Posted August 18, 2025 Author Share Posted August 18, 2025 Please sign in to view this username. Dear Richard, I will test the content you shared. Do you have a script for automatically refreshing reports? If so, could you share it with me? Thank you. Link to comment Share on other sites More sharing options...
