GX Callout / Distance Inner Planes
I don't run into this that often, but when you see an inner distance dimension, followed by the tolerance and GX, you would want to evaluate the two planes individually with Inner Tangential Element?
Thanks!
best way should be the Symmetry Plane (Features -> Special Geometries -> Symmetry Plane), evaluation to outer tangential element or maximum inscribed element (it´s the same in this case). You will have to recall the points from you measured planes
Edited
  • Like! 2
