[Jo...] Posted August 18 Share Posted August 18 I don't run into this that often, but when you see an inner distance dimension, followed by the tolerance and GX, you would want to evaluate the two planes individually with Inner Tangential Element? Thanks! Link to comment Share on other sites More sharing options...
[Ha...] Posted August 18 Share Posted August 18 From what I can bring up in Calypso, it appears that you would want outer tangential element instead. 1 Link to comment Share on other sites More sharing options...
[Je...] Posted August 19 Share Posted August 19 (edited) best way should be the Symmetry Plane (Features -> Special Geometries -> Symmetry Plane), evaluation to outer tangential element or maximum inscribed element (it´s the same in this case). You will have to recall the points from you measured planes Edited August 19 2 Link to comment Share on other sites More sharing options...
