[Ba...] Posted August 18, 2025 Share Posted August 18, 2025 With calypso 7.6 I had a new quick access pin menu pop up when I went to Open Measurement Plan. I recently tried to removed a program from this list and now the whole pop up is gone. I CANNOT find any options related to this menu. Anyone have any idea how to turn this back on? Many Thanks. Link to comment Share on other sites More sharing options...
[Ke...] Posted August 18, 2025 Share Posted August 18, 2025 (edited) https://portal.zeiss.com/knowledge-base?id=1444152 Here is some documentation on that menu,at the bottom are 2 ways to restore it if it is removed. "If one would like to disable the window you can “Right Click” > Don’t show favorites again. To undo this setting delete the CALYPSOFileDialog.exe folder located at C:\Users\<USERNAME>\AppData\Local\Carl_ZEISS_Industrielle_M (Note: AppData is a hidden folder, double check that you PC is set to View > Hidden Items.) " Edited August 18, 2025 1 Link to comment Share on other sites More sharing options...
[Ba...] Posted August 18, 2025 Author Share Posted August 18, 2025 That did it. Thank you so very much! 1 Link to comment Share on other sites More sharing options...
