XXT How slow do i have to go to avoid air scanning?
XXT Articulating head.
Im having a terrible time writing programs and no matter how slow i go i get rescans and "Scanning Optimization".
Im as slow as 0.150 inch on a 1 inch diameter circle to avoid the rescans
Is there a trick i need to know? is there a setting for the Scanning Optimization?
Right now im pretty much using points on all my circles.
You could pre scan a feature with points. I think you can do that in feature projection - not sure exact name, but a few month back it was debated here on forum.
  • Like! 2
As Martin says you can measure, typically a 4 point circle, I name it Pre-Circle1 prior to your scanned Circle and then go to the scanned circle Projection and choose Ref Feature and select the Pre-Circle1. This will probe the 4 point circle for location then use this circle as the reference location.
As Martin was saying, you could have it probe (4) points before measuring. Projection - Meas. Ref. - Own Geometry.
Unfortunately this only works for Circles. 😞
As for the optimal speeds, I tend to follow the cookbook when it comes to the XXT. On a 1" diameter, the cookbook would suggest a 2mm/sec for Form, 3mm/sec for Diameter, and 5mm/sec for Position.
There are times where you are going to get Scanning Optimization no matter what - especially as the feature size gets smaller and smaller.
You can turn it off in Resources - Compatibility Settings, but please note that it is for the entire measurement plan, not just one feature, so use at your own caution.
I have found that most of my air scanning warnings are due to location of a feature.
It could be from incorrect nominals, or it was machined off nominal, typically this happens when a feature location is as little as .007" from nominal.
Dear Mr. Stehlin,
How to access this knowledge base?
If I try to follow your link, i get a "page not found" message. Or is this knowledge base only accessible for US?
Regards
Karsten
I'd be very curious to know what the ZEISS™ Official™ positioning error threshold is for the "expected measuring force" message to appear, as well as the threshold for scanning optimization. I know it's more complicated than just positioning error, but that's the primary factor.
You've seen .007" in your experience, I have notes that say 0.1mm/.004", and the value I've parroted (though I can't remember where I first heard it) is .006", which agrees with my experience. I imagine it should be relatively consistent, and the decision of whether to perform pre-positioning can have a significant impact on cycle time.
The .007" came from collecting data of off a nominal feature as machined, it is an average of deviations of 50 samples. The samples were from a Ø.125 hole at a compound angle, difficult to set a center drill let alone drill the location to 1.10" depth (Thru). It made a good target as its location varied from nominal on average.
It wasn't a full-blown investigation, I just wanted to know when scanning optimization most likely occurs.
