[De...] Posted August 21, 2025 Share Posted August 21, 2025 Was wondering if anyone has any experience using GitHub / VS-Code / with Zeiss Inspect Apps. I am a little new to GitHub and would like to replicate what I see on https://github.com/ZEISS/zeiss-inspect-app-examples I have a ton of scripts and it would be really helpful to utilize github to record changes, documentation...etc. I have a company GitHub account, installed the vscode extension, git for windows, and am referencing: https://code.visualstudio.com/docs/sourcecontrol/github I'm just a little unsure how everything works with the Apps and the Edit Mode. Link to comment Share on other sites More sharing options...
[Ri...] Posted August 22, 2025 Share Posted August 22, 2025 I use GitHub with VSCode to controls revisions of a custom python application that I have developed for internal usage. The integration is somewhat straightforward. I would recommend getting the GitHub Desktop application. Feel free to reach out via PM, so I can assist more. Link to comment Share on other sites More sharing options...
[De...] Posted August 23, 2025 Author Share Posted August 23, 2025 I guess i'm wondering about the App & edit mode & the best way to navigate this... if the app is in edit mode its a regular folder structure with a unique ID as subfolder (dont know if this changes...? ) when its not in edit mode the app is a .addon (essentially a .zip file). should I be using the or the public_folder/gom_addons as the repository. (can Github extract the .addon zip structure?) or should I use the the public_folder/gom_edited_addons as the repository with the unique ID subfolder (that might change every time its edited?) Link to comment Share on other sites More sharing options...
[Ma...] Posted August 28, 2025 Share Posted August 28, 2025 Please sign in to view this username. There is another way of handling ZEISS INSPECT Apps: Just keep your App in some folder (e.g. Documents\apps\my_app and set up Documents\apps as Connected Folder in the App Explorer. This way you can edit/run your App from ZEISS INSPECT and edit, use source control etc. from VSCode. (Note: You can export the App from a connected folder, but you cannot "Finalize" it.) Just keep in mind that you might have to run gom.script.sys.update_addon_database() (from any App or configured as a menu item) to make changes made externally visible in the App Explorer. Link to comment Share on other sites More sharing options...
[De...] Posted September 9, 2025 Author Share Posted September 9, 2025 Thanks Please sign in to view this username. - Thats been working great so far!! Link to comment Share on other sites More sharing options...
