[Lu...] Posted August 22, 2025 Share Posted August 22, 2025 Hello, soon I will be working on transferring calypso from a windows 10 pc that is running calypso 2021, to a new pc where i will install calypso 2025. I have been doing research to prepare, but before I started i figured id ask if anyone has any tips that they have found helpful to do before/while moving to a new pc/new version? I have never done this before and the people who did this in the past have either left my company or don't remember it that well. Thanks! Link to comment Share on other sites More sharing options...
[Ma...] Posted August 22, 2025 Share Posted August 22, 2025 I've done a nee pc. I don't know how much you need ECC memory, so we got normal ones and i've choosed i5-14 gen. Zeiss preffer intel xeon - it's more server cpu because it can handle more memory. Otherwise at lest 32 gb ram and recommended graphics card - we have nvidia t1000 8gb. Then you have to have 2nd network connection - 1st for internet 2nd for machine. 1 Link to comment Share on other sites More sharing options...
[Ow...] Posted August 22, 2025 Share Posted August 22, 2025 (edited) Just upgraded a Duramax running Calypso 2014 on a Windows 7 computer to Calypso 2025 running Windows 11. I suppose every system has it's own prescription but, with no bells or whistles, just plain Calypso with no add-ins, the attached worked almost seamlessly. I'll attach the computer requirements recommended by Zeiss and also attach a document showing all the files that must be backed up. I believe the computer requirements were entry level? The licensing tool Zeiss uses has changed and you'll have to download it as well. The Calypso interface did have a big visual change in 2022 with new symbols and colors (no colors), that takes some getting used to. PC transfer or Calypso Backup_2025_.pdf Zeiss CMM computer requirements 2024-2025.docx Edited August 22, 2025 3 Link to comment Share on other sites More sharing options...
[Ab...] Posted August 25, 2025 Share Posted August 25, 2025 Hello Here is a helpful guide on backup files , install calypso and update license https://portal.zeiss.com/knowledge-base?id=1417384 1 Link to comment Share on other sites More sharing options...
[Ab...] Posted August 25, 2025 Share Posted August 25, 2025 another helpful guide is calypso Windows Operating System Version Support https://portal.zeiss.com/knowledge-base?id=815374 1 Link to comment Share on other sites More sharing options...
[Va...] Posted August 28, 2025 Share Posted August 28, 2025 When moving to a new PC/version, make sure you back up your configurations, stylus systems, and measurement plans from the old Calypso installation. Also copy over any CMM settings (like machine parameters and environment settings) so you don’t have to reconfigure from scratch. It’s a good idea to test the installation with a small project first, just to confirm everything transferred correctly before going live with production programs. 1 Link to comment Share on other sites More sharing options...
[Za...] Posted September 19, 2025 Share Posted September 19, 2025 even for folks who are not experiencing the issue outlined in the article below, i still recommend all users have their graphics settings optimized as mentioned here: https://portal.zeiss.com/knowledge-base?id=1596796 Link to comment Share on other sites More sharing options...
[Re...] Posted September 20, 2025 Share Posted September 20, 2025 Hallo kann man das Dokument bitte per PDF bereitstellen. Bei mir wird nichts angezeigt. Danke Link to comment Share on other sites More sharing options...
[Ca...] Posted September 20, 2025 Share Posted September 20, 2025 Unfortunately, access from Germany is not enabled Link to comment Share on other sites More sharing options...
[Ma...] Posted September 20, 2025 Share Posted September 20, 2025 Please sign in to view this username. Please sign in to view this username. Link to comment Share on other sites More sharing options...
