[Ma...] Posted August 28, 2025 Share Posted August 28, 2025 Has anyone had error code -1215 pop up when running your master probe to set the sphere position? Link to comment Share on other sites More sharing options...
[Lu...] Posted August 28, 2025 Share Posted August 28, 2025 Hi Manny, A 1215 error most often indicates a component involved is loose, dirty, or broken. These articles may be helpful: https://portal.zeiss.com/knowledge-base?id=1105583 https://portal.zeiss.com/knowledge-base?id=625020 1 Link to comment Share on other sites More sharing options...
[Ma...] Posted August 28, 2025 Author Share Posted August 28, 2025 Lucas thank you. I will visually inspect the sphere and the master probe. Link to comment Share on other sites More sharing options...
