Inspection Optimizer
How long does it take to run thru the Inspection Optimizer?  I just passed 1,000 seconds, over 2.43m iterations.
I read the KB article and noticed the operator is supposed to stop the operation.  My problem was the window was clipped on my laptop and I couldn't see the stop button.  I am trying again.
Edited
Typically it is pretty quick. I was under the impression that you are supposed to stop it once you see no change in improvement - otherwise yes it will run forever.
  Once I read the KB, I understood the process better.  When watching the process, the first 2 bars were blue and the rest were red. I later realized that maybe the red was telling me the solutions were not optimal and to give up.  Anyway, I got it to work but felt like I could do a better job by manually ordering my features.  The new problem is I no longer have an option to run from "From Features list". Just the "Optimized Feature order" or "From Characteristics list".  I couldn't find anything addressing this, but I am going to try deleting the "sorting" folder which contains the optimized list.
Update - deleting the folder worked
Edited
  • Like! 1
