[To...] Posted September 10 Share Posted September 10 Is there any reason why this part can't be checked with a single down stylus? The major dia. of top gear is Ø.755" and the lower gear is Ø1.555" Does the letter "A" in the tooth quality mean anything. It appears GearPro only shows a number. Thanks in advance. Link to comment Share on other sites More sharing options...
[Ch...] Posted September 10 Share Posted September 10 (edited) Tom, no reason, just be careful of shanking for profile and if there were any lead crowning etc. "A" refers to the spec, they're kind of broken up into 2, one for analytical, one for composite roll testing. Good thing is just choose AGMA 2015 and class # in Gear Pro and it will take care of the tolerance. Edited September 10 1 Link to comment Share on other sites More sharing options...
[Ch...] Posted September 10 Share Posted September 10 (edited) Edited September 10 1 Link to comment Share on other sites More sharing options...
[Ri...] Posted September 10 Share Posted September 10 The Gear Gods will strike you down if you don't use an L-probe, a Rotary Table, and you better make sure your Lead is measured bottom to top! 3 Link to comment Share on other sites More sharing options...
[Ch...] Posted September 10 Share Posted September 10 Gear God here, (j/k), Actually anytime I can measure without rotary table straight down I would, 1 less source of error. I do however prefer R/T over say a 10x star stylus system. Good luck, let us know how you make out. 1 1 Link to comment Share on other sites More sharing options...
[Ri...] Posted September 10 Share Posted September 10 Yeah - I agree with that. I've had to measure helical gears with an XTR - and while I was successful, it would have been much simpler and more efficient to have had an RT. 2 Link to comment Share on other sites More sharing options...
