[Ed...] Posted September 10, 2025 Share Posted September 10, 2025 Hello, Fairly new to Calypso. I have 2 parallel Planes and would like to construct a Plane which will become one of my Datums. I have a STP file - CAD Model. Thank you in advance. Link to comment Share on other sites More sharing options...
[Ma...] Posted September 10, 2025 Share Posted September 10, 2025 If they are parallel but different height, then you would need to use stepped plane. Link to comment Share on other sites More sharing options...
[To...] Posted September 10, 2025 Share Posted September 10, 2025 (edited) Please sign in to view this username. Simple version. Extract 2 planes and assign them as Feature 1 and Feature 2 in a Symmetry Construction. If MMB/LMB is required on any GD&T characteristics, create a Symmetry Plane (Special Geometry) and use "recall the feature points from the 2 planes into the Symmetry Plane. It's best to do this from a CAD model before there is any data in the 2 planes. Otherwise, you will need to verify the nominal data is correct in the Symmetry Plane. Edited September 10, 2025 1 Link to comment Share on other sites More sharing options...
[Lu...] Posted September 19, 2025 Share Posted September 19, 2025 How I do it (Calypso 2018): 1. Define and probe plane(s) features on one level 2. Define and probe point(s) features on planes on other levels 3. Offset the point(s) feature(s) by nominal distances 4. Define the final plane by Recall of the Plane Feature(s) from first step and offset point(s) from third step Pretty much of an effort Link to comment Share on other sites More sharing options...
