[M1...] Posted September 12, 2025 Share Posted September 12, 2025 (edited) Hello, I have a program where I qualify and save the RT-axis in postsettings with command saveRotaryTableData("testx1") I another program I load it in presettings with command loadRotaryTableData("testx1") Is this the correct way to do it? Asking because I can not see that the date and time is updated in the window for the RT-axis. I am testing this because it would be a good thing to implement when using different parts and when its not always possible to measure RT-axis on the part itself. Edited September 12, 2025 spelling Link to comment Share on other sites More sharing options...
[Ch...] Posted September 12, 2025 Share Posted September 12, 2025 (edited) Hi, This is why I requested this feature a while back , good to see others are interested in it. Anyways you can also use this PCM to get the RT-Axis Date : getRTData("axisDate") Maybe this will help. Also, if you know for example one of the values such as 'angleToMainAxis' from the saved file, you can confirm that also with PCM. Also , I'm told loading RTAxis is not designed to work in simulation. Good luck. Edited September 12, 2025 2 Link to comment Share on other sites More sharing options...
